Activity Forums Adobe After Effects looping
  • Jim Kanter
    November 22, 2005 at 2:37 am
    The trick is to make sure that the loop ends on the frame before you return to the original values.
    E.G.: if you set a keyframe with a value of 1 at 0:00 and again at 0:09 and a keyframe in the middle with the value of 5, the frame values will interpolate to
    1 2 3 4 5 4 3 2 1
    so when it loops it goes
    1 2 3 4 5 4 3 2 1 1 2 3 4 5 4 3 2 1 1
    and so on. The trick is to end the loop at 0:08 so that the next frame in the interpolation sequence will be the value at the start of the loop:
    1 2 3 4 5 4 3 2
    will loop as
    1 2 3 4 5 4 3 2 1 2 3 4 5 4 3 2 1 etc.
    Jim Kanter,
    Digital Film Institute
    http://www.dfilminst.com
  • Kelly Johnson
    November 23, 2005 at 10:42 pm
    jeez, that makes total sense and in Flash I always do that. Good to hear it to get it again, thanks!!
