Activity › Forums › Adobe After Effects Expressions › loopIn & loopOut a linear() expression
  • loopIn & loopOut a linear() expression
    Posted by Javi Gil on September 30, 2022 at 2:21 pm
    Hi!
    I have this project where I need to have layer markers to determine when the loop point happen. The problem is that it is going to be a lot of duplicated layers with the exact same set up, and I need this to loopIn and loopOut, to still have looping animation before the first marker and after the second one.
    Basically what I need is that if I have the first marker at time=0 and the second one at time=10, I want the timeremap to go from 0secs to 5secs between this two markers, and have it loopIn(“cycle”) and loopOut(“cycle”) with this new animation.
    Right now I have this:
    mark1 = thisLayer.marker.key(1).time;
    mark2 = thisLayer.marker.key(2).time;
    mark0 = mark1-(mark2-mark1);
    pos1= 0;
    pos2=10;
    loopNumber = Math.floor(time/mark2);
    if (mark1>0 && time<=mark1) {
    linear(time, mark0,mark1,pos1,pos2)
    } else if (time<mark2 && time>mark1){
    linear(time,mark1,mark2,pos1,pos2)
    } else {
    mark1 = mark2*loopNumber;
    mark2 = mark2*(loopNumber+1);
    linear(time, mark1,mark2,pos1,pos2)
    But for whatever reason it seems to jump frames at some point, so I can’t make it loop if I offset any of the layers.
    Any idea??
    Thank you!!
    JaviG
    Javi Gil replied 3 years, 12 months ago 2 Members · 4 Replies
  • Dan Ebberts
    September 30, 2022 at 2:46 pm
    I think this might be close to what you’re looking for:
    m1 = thisLayer.marker.key(1).time;
    m2 = thisLayer.marker.key(2).time;
    pos1 = 0;
    pos2 = 10;
    d = m2 - m1;
    offset = d - m1%d;
    t = (time + offset)%d;
    linear(t,0,d,pos1,pos2)
  • Javi Gil
    September 30, 2022 at 2:51 pm
    This works like a charm Dan! Thank you so so much!!
    Just so I can understand it, what does the “%” renders?
    Again, thank you SO much!
  • Dan Ebberts
    September 30, 2022 at 3:02 pm
    % gives you the remainder of a division operation. So 10.5%3, for example, would give you 1.5
  • Javi Gil
    September 30, 2022 at 3:10 pm
    oooouh! I see!!
    Thank you again Dan!
