Activity › Forums › Adobe After Effects Expressions › looped composition causes frame mashup
  • looped composition causes frame mashup
    Posted by Juergen Schuette on September 25, 2014 at 1:40 am
    hello,
    i am running ae cs6 on osx 10.9.4 here and ran into a rather strange problem,
    i am using time remap and this expression: loopOut(type = “cycle”, numKeyframes = 0)
    to get character sprites animated ..
    at some point i noticed that the looped/ extended composition is flickering from time to time,
    i do get flickering that seems to consist of all the animation’s singluar frames displayed at once .. i have no idea why that happens..
    at first i thought it might just be a playback issue and a restart of ae fixed the problem… well, i was wrong..
    does anybody know this problem or even better knows how to fix it?
    so long,
    juergen
    Matt Orfalea replied 11 years, 10 months ago 3 Members · 3 Replies
  • Dan Ebberts
    September 25, 2014 at 3:36 am
    As I recall, when you loop time remapping like that, once you enable time remapping, you need to set a keyframe the frame before the last keyframe that AE creates, then set the value of AE’s last keyframe to zero. I don’t know if that’s the root of your problem, but that’s my guess.
    Dan
  • Juergen Schuette
    September 25, 2014 at 4:23 pm
    hey dan,
    i got to tell you, when working on my current project i was searching a lot for expressions and other ae related stuff, i always bumped into one of your posts and usually you were providing the answer to the problem.. impressive and great. thanks for that.. : )
    your guess concerning my current problem ain’t the solution, sadly..
    i am aware of the create- a- frame-behind-the-last-frame-set-by-timeremap-and-replace-said-frame-with-your-newly-created-frame issue ..
    my loop does not suffer a gap but a mashup of all the frames the initial animation consists of, a character is walking (say 7 frames) and in the looped composition at some point all 7 frames are piled up, this happens repeatedly
    thanks for the effort though ..
    turns out that once this issue occurs in the project and i render the clip anyway, then i will have the mashup in the video file as well
    but if i restart ae and reopen the project before rendering the file comes out clean…
    strange
  • Matt Orfalea
    November 13, 2014 at 5:10 pm
    I’m experiencing the same strangeness.
    But I’m glad you mentioned restarting worked for you. Worked for me too. I just hope I don’t have to restart every time I make a new loop…
    —check me out
    https://www.youtube.com/orf
