Activity Forums Adobe After Effects Expressions Loop Wiggle expression
  • Loop Wiggle expression
    Posted by Ashley M. kirchner on April 10, 2009 at 6:57 am
    I have a 10 second comp with several layers on it. Each layer has a wiggle expression. When I loop this comp, you can clearly see the difference between the last frame and first frame each time it loops. Is there a way to fix this, so it’s seamless?
    Winston Hartle replied 8 years, 9 months ago 4 Members · 7 Replies
  • 7 Replies
  • Dan Ebberts
    April 10, 2009 at 3:33 pm
  • Ashley M. kirchner
    April 12, 2009 at 4:25 pm
    Awesome! That’s exactly what I needed. Thanks!
  • Sam Begdouri
    August 5, 2015 at 4:57 pm
    How do I use this x,y,z wiggle expression
    a =wiggle(0.2,150);
    b =wiggle(0.15,160);
    c = wiggle(0.2,500);
    [a[0],b[1],c[2]]
    to go with this expression seemless loop expression
    freq = 1;
    amp = 110;
    loopTime = 3;
    t = time % loopTime;
    wiggle1 = wiggle(freq, amp, 1, 0.5, t);
    wiggle2 = wiggle(freq, amp, 1, 0.5, t – loopTime);
    linear(t, 0, loopTime, wiggle1, wiggle2)
    a =wiggle(0.2,150);
    [a[0],b[1],c[2]]
    freq = 1;
    amp = 110;
    loopTime = 3;
    wiggle2 = wiggle(freq, amp, 1, 0.5, t - loopTime);
  • Dan Ebberts
    August 5, 2015 at 6:01 pm
    Try this:
    loopTime = 3;
    a1 = wiggle(0.2, 150, 1, 0.5, t);
    a2 = wiggle(0.2, 150, 1, 0.5, t – loopTime);
    b1 = wiggle(0.15, 160, 1, 0.5, t);
    b2 = wiggle(0.15, 160, 1, 0.5, t – loopTime);
    c1 = wiggle(0.2, 500, 1, 0.5, t);
    c2 = wiggle(0.2, 500, 1, 0.5, t – loopTime);
    linear(t, 0, loopTime, [a1[0],b1[1],c1[2]], [a2[0],b2[1],c2[2]])
    Dan
  • Winston Hartle
    November 27, 2017 at 9:14 am
    dan, your looping wiggle expression has been such an asset for me so many times so thank you! i’ve run into somewhat of a wall with it when being applied to a camera’s ‘point of interest’ in a 3D composition, however.
    in the simplest reproduction of my issue, i have a stationary, two-node camera whose ‘point of interest’ value animates across any given length of time (as few as two keyframes). when i apply your expression to the ‘point of interest’, i find that it animates completely differently from how it should – it’s as if the expression is causing an issue with the keyframed values? when i clear the expression and enter a non-looping, regular wiggle [IE wiggle(2,5);] the animation is restored…any idea why this would be?
    thanks so much in advance – it’s much appreciated!!
    PS: side note, is it possible to set the loop time in fractions of seconds, and how would you do that? would a value of ‘3.20’ loop every 3 seconds and 20 frames?
    freq = 2;
    amp = 5;
    loopTime = 3;
  • Dan Ebberts
    November 27, 2017 at 5:09 pm
    >.any idea why this would be?
    The looping wiggle expression, as you have it set up, will be a blend of two wiggled segments–one from -3 to 0 seconds and one from 0 to +3 seconds. How well this matches up with your keyframes would just be coincidental. It sounds like you need a different design, tied to your keyframe timing, but I’m not sure what that would be exactly.
    loopTime is in seconds, so if you want 3 seconds and 20 frames, you could do it like this:
    loopTime = 3 + framesToTime(20);
    Dan
  • Winston Hartle
    November 30, 2017 at 10:49 pm
    hey dan,
    i really appreciate you taking the time to comment and help me out, so thanks!
    have a good one ☺
    winston
