Activity › Forums › Adobe Audition › Loop while recording in Multitrack
  • Loop while recording in Multitrack
    Posted by Robert Bush on September 15, 2006 at 2:42 pm
    I keep reading the Help file over and over but can’t seem to get this feature to work for me. When I reach the end of my “selection” or “view” playback stops. What I want to do is have the track loop so I can try multiple passes at it until I feel I have a good performance or can comp one from what I’ve got. Am I misunderstanding what this feature is? Should I be able to loop the playback and record to successive tracks each time. I’m a little lost on this one.
    Willie Toth replied 20 years ago 2 Members · 1 Reply
  • Willie Toth
    September 15, 2006 at 4:36 pm
    Right click on the track then go to LOOP PROPERTIES when the page comes up check ENABLE LOOPING and hit OK … Now you will have to put the pointer on the lower right corner of the clip left click and hold … You will now be able to drag the clip out for as long as you want … Is this clip one you composed or is it out of the loopology folder? If it is a loop you composed you may have issues with a clean loop … If you have any questions write back ……………. WILLIE
