Activity Forums Adobe After Effects loop swf animation
  • loop swf animation
    Posted by Jason Brown on June 18, 2009 at 3:03 pm
    Hey Guys,
    I have a swf exported from Flash where the last frame is the same as the first frame. It only lasts 3 seconds…but I need it to loop for 45 seconds or so.
    Is there another way (besides creating 10-15 layers) to loop that animation? I have 4 other layers that I need to do this to at the same time…I see my layers getting out of control!
    -Jason
    Jason Brown replied 17 years, 2 months ago 2 Members · 2 Replies
  • Kevin Camp
    June 18, 2009 at 3:39 pm
    hi jason,
    there are 2 ways…
    one way, select the footage in the project window and choose file>interpret footage>main… at the bottom of that window you can set the number of loops. when you drag that footage into a comp it should now loop that number of times.
    another way, select the footage in the timeline and choose layer>time>enable time remapping. add an expression for the time remapping property (animation>add expression) and type: loopOut(), you may need to extend the out-point of the layer for as long as you need it. but now the footage will loop indefinitely.
    i prefer the later way for looping. it allows for tweaking of the loop… say the last frame is actaully a duplicate of the first frame, and you don’t want that little hitch, just add a time remap keyframe one frame in from the last keyframe and delete the last keyframe. you have now trimmed that last duplicate keyframe out.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Jason Brown
    June 18, 2009 at 4:05 pm
    you’ve answered a question of mine before…thanks again! You are a freakin’ genius!!
    I completely forgot about the looping number in intrepret footage dialogue…
    I don’t need to truncate any frames…my designer ended the design with the intention to loop with the next being frame 1. But I like the expression idea, I’ve used the looping expression before, but I’m not very good with expressions.
    Thanks again!
    -Jason
