Loop Region Problem
Posted by Treva Mello on March 17, 2018 at 6:50 pmHi guys.
Vegas always renders loop region bigger than it is, it adds about 00:00:00.01 in the beginning and in the end.
How can I fix that?
Is there a setting for it?
I googled but found nothing.
Thanks.Treva Mello replied 8 years, 4 months ago 3 Members · 30 Replies -
Graham Bernard
March 18, 2018 at 12:02 pm[Treva Mello] “Vegas always renders loop region bigger than it is, it adds about 00:00:00.01 in the beginning and in the end.”
How do you know? Where are you seeing this incorrect length?
* Grazie
Cameras: Canon XF300 + PowerShot SX50HS Bridge -
Treva Mello
March 18, 2018 at 6:52 pmThe rendered file is bigger when I put it right below the original file and if I select it as a loop region, Vegas shows it’s bigger.
If I zoom it in, I can see there’s nothing at the beginning and end of the audio track and when I play it, there’s black screen (nothing) in the beginning and in the end.
Of course it’s a very tiny part but with a bunch of different files (scenes), those parts add space and get images and sounds out of sync.
I have to keep cutting those tiny parts = Hell. -
Graham Bernard
March 18, 2018 at 7:14 pmPlease show us a screengrab.
* Grazie
Graham Bernard
March 18, 2018 at 8:01 pmMaybe there’s a visual clue that will tell me something.
* Grazie
Graham Bernard
March 18, 2018 at 8:23 pmNope.
* Grazie
Treva Mello
March 18, 2018 at 9:34 pmHi Mike.
I think probably sometimes it was enabled and sometimes not.
Does it make a difference?
That could be the problem?
So should I let it enabled or not when rendering?In my mind (a crazy mind for sure), no matter whatever settings Vegas has, if there’s a loop region and I render it, it should render only that loop region…………………..period.
Not?
