Activity Forums Adobe After Effects Expressions Loop Random Velocity
  • Loop Random Velocity
    Posted by Luke Regan on April 10, 2014 at 6:11 pm
    I need to loop an object moving from top to bottom of the screen at random speeds/velocity.
    Let me explain further what I mean. I have two keyframes for an object’s y value. It starts on the top of the screen and ends at the bottom of the screen. Pretty simple. I then added a loopOut(“cycle”) expression so the object continually loops, moving from the top of the screen to the bottom, over and over. Perfect…
    Now what I need is for the object’s velocity or speed to randomly change each time it loops. Basically I want the time it takes the object to reach the bottom of the screen to be different every time it loops.
    How can I do this using expressions? Thanks!
    Luke Regan replied 12 years, 5 months ago 2 Members · 2 Replies
  • Dan Ebberts
    April 10, 2014 at 6:36 pm
    This is one way. Adjust minDur and maxDur to get the range of transition times you like:
    minDur = .5;
    maxDur = 2.5;
    if (numKeys > 1){
    t = tPrev = inPoint;
    seedRandom(index,true);
    while (t <= time){
    tPrev = t;
    t += random(minDur,maxDur);
    linear(time,tPrev,t,key(1).value,key(2).value);
    }else
    value
    Dan
  • Luke Regan
    April 10, 2014 at 9:53 pm
    Thanks Dan! This works perfectly.
    Any chance you could briefly explain how the code snippet works?
