Activity Forums Adobe After Effects Expressions Loop out at marker
  • Loop out at marker
    Posted by Edward Clayton on June 28, 2022 at 7:49 pm
    Trying to work out an expression that will loopOut() Time Remap keyframes starting at a marker.
    startMarkerTime = thisLayer.marker.key(1).time;
    I can get the animation to start at the marker, but not loop:
    if (time <= startMarkerTime) {
    0
    } else {
    time - startMarkerTime
    Or I can get the loop to start at the marker, but not from the first frame:
    0
    } else {
    loopOut()
    How can I get the animation to start at the marker AND loopOut starting from the first frame?
    Edward Clayton replied 4 years, 2 months ago 2 Members · 5 Replies
  • Dan Ebberts
    June 28, 2022 at 8:59 pm
    Probably close to this:
    startMarkerTime = marker.key(1).time;
    0;
    } else {
    (time - startMarkerTime)%(key(numKeys).time - key(1).time);
  • Edward Clayton
    June 28, 2022 at 9:40 pm
    Yes, this works great! Any way of getting this to boomerang ( i.e. loopOut(“boomerang”) ) without it using the loopOut function?
  • Edward Clayton
    June 28, 2022 at 9:59 pm
  • Dan Ebberts
    June 28, 2022 at 10:26 pm
    Do you mean “pingpong”? That would be like this I guess:
    0;
    } else {
    t = time - startMarkerTime;
    t1 = key(1).time;
    t2 = key(2).time;
    d = t2 - t1;
    n = Math.floor(t/d);
    n % 2 ? t2 - t%d : t1 + t%d;
  • Edward Clayton
    June 28, 2022 at 11:19 pm
    Ah yes, I meant pingpong. Perfect! Thank you, Dan.
    FYI, I had to change key(1).time to key(1).value
