Activity Forums Adobe After Effects Expressions Loop nested comp (easy i know)…
  • Loop nested comp (easy i know)…
    Posted by Harry Hoag on April 6, 2009 at 6:45 pm
    Ok, I have a nested comp, in which is a single time remapped layer.
    I’ve added an expression to the nested comp: loopOut(“cycle”)
    But it’s not looping smoothly, it seems to be spitting out a loop of random(ish) frames…
    is this the right code to use?
    thanks
    Eric Sanderson replied 17 years, 5 months ago 4 Members · 3 Replies
  • Kevin Camp
    April 6, 2009 at 8:38 pm
    since ‘cycle’ is the default, you can try just loopOut()…
    but i have a feeling ae is just acting up, try choosing edit>purge>all from the menu to see if that may help clear things out of ae. if that doesn’t work, try a reboot of the machine.
    if none of that works respond back…
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Pierre-alexis Tremblay
    April 7, 2009 at 2:38 pm
    Hi, I once had this problem and resolved it by adding a time remap keyframe at frame -1.
    But I’m not sure why it worked…
    P.A.T.
  • Eric Sanderson
    April 7, 2009 at 7:21 pm
    well first thing you have to make sure is that your comp is even “loopable”, by making your first and last frame the same, then putting the keyframe either after your first frame or the frame before the last so it doesnt duplicate that exact frame. If you have set it up that way than it does sound like you could be having some RAM issues.
