Activity Forums Adobe After Effects loop in AND loop out
  • loop in AND loop out
    Posted by Marc De coster on June 22, 2010 at 9:50 am
    Hi! New problem …
    I have a project where some layers rotate around a globe (it’s not for me, it’s for a training session I give!)
    and here is my problem: I wrote an expression to loop my rotation loop_out(“cycle”,0) and, of course, it works. Now, I wanted to have the same rotation withe a loop in. So I added a line to my expression:
    loop_in(“cycle”,0)
    loop_out(“cycle”,0)
    and it doesn’t work. I have a loop in OR a loop out but I can’t have them both on the same layer. May be I should add something between my two expressions?
    Any ideas?
    Thank u guys
    Roei Tzoref replied 5 years, 2 months ago 5 Members · 7 Replies
  • 7 Replies
  • Michael Szalapski
    June 22, 2010 at 1:22 pm
    You need ; after each line of code.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Kevin Camp
    June 22, 2010 at 1:44 pm
    what’s happening is the last statement is the one that ae will execute. so, loop_out is the only one you will see.
    what you’ll need are some conditional statements that will make each statement get executed when certain criteria is met — essentially, when time is less than when the rotation starts, loopIn; when it is after rotation ends, loopOut; if it is in between the keys, return the actual values…
    something like this should work:
    if (time=key(numKeys).time){
    value;
    }else{
    if (timekey(numKeys).time) loopOut();
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Kevin Camp
    June 22, 2010 at 1:59 pm
    oops, part of the expression was removed due to the symbols…
    lets try this again:
    if (time < key(1).time) loopIn();
    if (time >= key(1).time && time <= key(numKeys).time) value;
    if (time > key(numKeys).time) loopOut();
    that looks better, and it’s a little simpler than the original
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Marc De coster
    June 22, 2010 at 2:11 pm
    Yessss it works!
    Thank u. I thought it would have been easier but … expressions are always a pain in the ….
    However, I wouldn’t have find it by myself so … thank u
  • Richard Thompson
    August 21, 2012 at 10:55 pm
    Kevin that expression work is formidable. Really good stuff.
    whilst messing around with the expression to understand how it works I found you can reduce your code slightly into this…
    if (time < key(1).time) loopIn(“continue”);
    else (value);
    if (time > key(numKeys).time) loopOut(“continue”);
  • Roei Tzoref
    November 8, 2018 at 11:00 pm
    also this would work:
    loopIn()+loopOut()-value
    Roei Tzoref
    2D/VFX Generalist & Instructor
    ♫ AeBlues Tutorials ♫
    http://www.tzoref.com
  • Roei Tzoref
    June 15, 2021 at 6:30 am
    more like this:
    loopIn(“continue”)+loopOut(“continue”)-value
