Activity Forums Adobe After Effects Expressions Loop animation via expression.
  • Loop animation via expression.
    Posted by Konstantin Kartashov on July 9, 2016 at 1:10 pm
    Hi everybody!
    I`m trying to link playback of one object`s animation cycle to movement of another one. I use Duik morpher to link all keyframes to one slider and link this slider to x-position of null object. The point is to make it work in cycle. I actually done it (may be in a little weird way). See the code below.
    Here 15 is a length of animation cycle. It works, but have one issue – when position goes lower zero the loop stops playing. I understand why it behave this way, but don`t know how to fix it.
    P.S. sorry for cyrillic letters in the code, unfortunately I have russian version of AE. Пусто 1 equals Null 1.
    if ((thisComp.layer("Пусто 1").transform.xPosition) <15) (thisComp.layer("Пусто 1").transform.xPosition) else (thisComp.layer("Пусто 1").transform.xPosition)-(Math.round((thisComp.layer("Пусто 1").transform.xPosition)/15-0.5))*15
    Konstantin Kartashov replied 10 years, 1 month ago 2 Members · 4 Replies
  • Dan Ebberts
    July 9, 2016 at 3:29 pm
    Like this maybe:
    x = thisComp.layer("Пусто 1").transform.xPosition;
    if (x < 0)
    15 + x%15
    else
    x%15
    Dan
  • Konstantin Kartashov
    July 10, 2016 at 10:34 am
    Thank you very much, Dan,
    Everything`s works as needed. Could you please explain what “%” symbol means here?
  • Dan Ebberts
    July 10, 2016 at 1:54 pm
    That’s the JavaScript modulus operator, which returns just the remainder from a division operation. So the result of
    35 % 15 would be 5, for example.
    Dan
    July 10, 2016 at 3:19 pm
    cool! thank you again!
