Activity Forums Adobe After Effects Loop a write-on effect
  • Loop a write-on effect
    Posted by Timi Boose on August 19, 2014 at 12:03 am
    I am creating a simple drawing and animating the sun’s rays bouncing off a window to show how a certain type of glass in a window works. I animated the sun’s rays with the write-on effect and it works good but only goes 1 time. I want to loop the write-on effect so that it will happen repeatedly.
    I tried adding the expression loopOut(“cycle,0) …..onto the brush position control in the write-on effect but it still only goes one time….
    Declan Smith replied 12 years, 1 month ago 2 Members · 1 Reply
  • Declan Smith
    August 19, 2014 at 12:54 am
    You could try precomposing the brush layer and adjust it’s comp length needed to complete one cycle and then on the precomped layer in the main comp, add time-remap and then loopOut on that and drag the length to the end.
    Declan Smith
    https://www.madpanic.tv
    After Effects CS6/ FCS3 / Canon XLH1 / Canon 7D / Reason / Cubase
    “it’s either binary or it’s not”
