Activity › Forums › Adobe After Effects Expressions › Loop a nested compositon?
  • Loop a nested compositon?
    Posted by Francois Driessen on October 5, 2006 at 3:22 pm
    Hi there. Can’t find this in the help files – probably cause I’m asking the wrong question for AE.
    But Is there a quick way to loop a nested composition – so that once it reached the end of the nested comp’s duration, the main comp will just start paying frame one of the nested comp again? (Similar to using movie elements in Flash?)
    Francois
    >- e y e f l a m e .tv –< https://eyeflame.tv
    Francois Driessen replied 19 years, 12 months ago 3 Members · 6 Replies
  • Mylenium
    October 5, 2006 at 3:31 pm
    No. You need to render your pre-comp, use time-remapping or create the looping in the sub-comp itself.
    Mylenium
    [Pour Myl
  • Danny Princz
    October 5, 2006 at 4:10 pm
    just use timeremapping on the precomp layer and use a loop expression
  • Francois Driessen
    October 5, 2006 at 6:23 pm
    Sounds promising.
    Had not used expressions before. Need a bit more help if it could be explained in a quick couple of steps?
    Thnx!
    Francois
  • Mylenium
    October 5, 2006 at 7:29 pm
    Enable time remapping. Two keyframes at start and end will appear. Do nothing on them. Alt+click the stopwatch, type in loopOut(“cycle”,0).
    Mylenium
    [Pour Myl
  • Francois Driessen
    October 5, 2006 at 8:34 pm
    Thanks. Got a similar expression as what I tried to come op with form the Eeprxssions Help file. Doesn’t work for some reason. So, for now I’m just manually copy & pasting time remap keyframes on the nested layer. That’s fool proof. Would be nice to be able to do it the more gracious expression way, though.
    Francois
  • Francois Driessen
    October 5, 2006 at 8:43 pm
    OK. Got it. Helps if you move your out point too on the layer. Somehow this one got left behind when I extended the comp time.
    THNX it works!
    Francois
