Activity Forums Adobe After Effects Expressions Loop 3 values over time without keyframes
  • Loop 3 values over time without keyframes
    Posted by Pete Menich on May 3, 2022 at 2:55 pm
    I’m trying to set up an expression that loops 3 values & can’t get it to work.
    for example; opacity is 0% at 0 seconds, 0% at 1 second, the 100% at 2 seconds & then goes back to 0%.
    I’d usually just keyframe this and then add a loopOut expression, but I want to be able to control the time between values with a slider to control speed.
    Any idea how to do that anyone?
    I’ve searched high and low & everything seems to reference only the expressions that work with keyframes.
    Pete Menich replied 4 years, 4 months ago 1 Member · 1 Reply
  • Pete Menich
    May 3, 2022 at 3:22 pm
    as usual, moments after posting I found a solution….
    linear(time%2, 1, 2,0,100)
