Activity › Forums › Maxon Cinema 4D › Looooooong render on Dual G5
  • Looooooong render on Dual G5
    Posted by Rob Hindley on September 13, 2005 at 10:56 pm
    I am using c4d 9.x and have modelled and rigged a character for testing. The mesh is not a high poly count and the textures are simple. But test rendering just 50 frames of a simple bowing movement grinds my Mac to halt. And I generally get a “Not Enough Memory” error. Even with no other apps open it happens. Can’t find anyhting in c4d prefs that helps. I have 2Gb of RAM.
    HELP!
    Rob Hindley replied 21 years ago 2 Members · 2 Replies
  • Simon Carlson-thies
    September 13, 2005 at 11:48 pm
    Do you have any volumetric effects in your scene? (Pyrocluster…)
    Good Luck
    Simon Carlson Thies
  • Rob Hindley
    September 14, 2005 at 5:53 am
    Found the problem – Hypernurb Render Subd was set to 6. I reset it to 3 and the machine happily chugged away!
