Activity › Forums › Apple Final Cut Pro › Looks like a bug?
Looks like a bug?
Posted by Nick Toth on July 13, 2011 at 10:54 pmWhen I import DVCPRO HD 1080i60 clips that were logged and transferred in FCP6 the inspector in FCP X shows they are ‘lower field’. In FCP 7 the item properties say “upper”. Clips imported into FCP X direct from the same camera (HVX200) show as “upper field” in both FCP X and 7. Anyone else see this?
Marc Newy replied 13 years, 11 months ago 5 Members · 5 Replies -
Mark Morache
July 14, 2011 at 5:30 amInteresting. Do you think it’s just mislabeled?
You can step through the fields holding down the option key as you hit right or left arrow.
You can also override the field order, so hopefully if it’s a bug, it’s not a deadly one.
Mark Morache
Evening Magazine
Seattle, WA
blogging at https://fcpx.wordpress.com -
James Bayliss-smith
January 2, 2012 at 9:50 amI’ve just completed a PAL edit with footage from P2 DVCpro using FCP X
After exporting from FCPX and trying to compress using a program called M-Link Newscaster I got an warning message saying
“This looks like a PAL video but but has an unexpected field order (top field first)”
Sure enough when I analyse the output file in VideoSpec it says the top field is first. When I analyse the footage (that I ingested with FCP 7) it is bottom field first. SO it has changed during the edit
Why has FCP X done this?
Does it matter (I have a feeling it does my content is destined for television news)
How do I solve this problem?Cheers
Steve Connor
January 2, 2012 at 11:05 amHow did you export and using what format, what are your project settings?
“FCPX Agitator”
James Bayliss-smith
January 2, 2012 at 1:29 pmProject Settings:
Video Properties: PAL SD – 720×576 Anamorphic – 25i
Export Settings- Share- Export media – Export – Video and Audio – Video Codec – current settings –
Marc Newy
October 24, 2012 at 3:34 pmHi James,
I am experiencing the same issues, trying to maintain interlaced video but FCPX via Compressor 4 is convert to progressive.
Did you find the fix for this ?
Thanks.
