Activity Forums Adobe After Effects looking up through water
  • looking up through water
    Posted by Jen Savage on February 6, 2006 at 8:00 pm
    A friend of mine made a short film, but due to the budget and the availability of his actor, he was unable to get a shot he wanted. The shot in question is an underwater point of view shot of someone looking up through the water at another person standing on the edge of a dock. He has the low angle shot, just not underwater. I tried using psunami (its been years since I touched it) but I haven’t been able to get anything remotely realistic. It looks like someone projecting colored streaks over the subject. Any help would be greatly appreciated. Thank you.
    Jen Savage replied 20 years, 6 months ago 3 Members · 4 Replies
  • Al
    February 6, 2006 at 9:39 pm
    displacement maps will be your friend 🙂
  • Jen Savage
    February 6, 2006 at 10:02 pm
    Hi, should I precomp a psunami layer and use that as a displacement map adjustment layer over my footage, or should I make a displacement map for the psunami layer?
  • Andrew Corneles
    February 7, 2006 at 5:56 pm
    Yeah Precomp the psunami, and use that as displacement for your vid layer.
    try different modes for the psunami over the video,
    I usually make a duplicate of displacements and time shift or scale them
    for the different effects to get a little more “realism” in how the layers play together.
    I would use the “blur effect that references layers”
    (can’t look rendering 🙂
    to add a little more “stuff” to the effect,
    and definitely color correction, etc.
    good luck!
    Andrew Corneles – http://www.efponline.com – editorial and mograph
  • Jen Savage
    February 8, 2006 at 5:49 pm
    Thank you very much for your help. The psunami displacement layers did the trick. 🙂
