Activity › Forums › Adobe Premiere Pro › Looking for volume control filter or plug
  • Looking for volume control filter or plug
    Posted by Oliver Peters on March 29, 2018 at 12:31 pm
    I’m looking for a loudness or volume control plug-in or app. This could be for Premiere or FCPX. Or standalone. Rendering versus real-time is fine. I am already familiar with VideoToolShed’s Loudness Change and iZotope’s RX Loudness Control.
    Typically the ones I’m familiar with will normalize a clip to a target volume based on the highest peak within that clip. This will bring the level of the entire clip up or down, but relative differences within a clip don’t change. I also don’t want a compressor, since those often sound too harsh. What I want is something more akin to Waves VocalRider.
    In other words, it will bring the peak levels down to a target setting, but also raise the quieter sections – all WITHIN a clip, not between clips. The result would be like riding levels, but without the need for keyframing the volume within a clip.
    Mac version. Suggestions? TIA.
    – Oliver
    Oliver Peters – oliverpeters.com
    Kevin Rag replied 8 years, 6 months ago 2 Members · 5 Replies
  • Kevin Rag
    March 29, 2018 at 1:18 pm
    Waves MV2, Waves Max Volume or PrPro’s Hard limiter, where you set a limit level and boost the input volume , these are the ones that come to mind:) Hope this helps Oliver.
    K
  • Oliver Peters
    March 29, 2018 at 2:00 pm
    Thanks. I’ve worked with the hard limiter and it crushed the peaks too much. But I’ll check out the Waves products. Although Vocal Rider might still be the best way to go.
    – Oliver
  • Oliver Peters
    March 29, 2018 at 2:04 pm
    [Oliver Peters] “Although Vocal Rider might still be the best way to go”
    Speaking of which, I see that right now it’s on sale for $29, instead of the usual $249!
    – Oliver
  • Oliver Peters
    March 29, 2018 at 3:52 pm
    Since Waves is having a sale right now, I ended up picking up MV2 and Vocal Rider dirt cheap. Both do what I want with somewhat different results. Thanks for the suggestion on MV2.
    – Oliver
  • Kevin Rag
    March 30, 2018 at 9:57 am
    My pleasure Oliver:)
    You’ve been helping a lot of people here for so long, I’m glad I could suggest something useful to you:)
    Kevin
    K
