Activity Forums DVD Authoring Looking for some advice on buring Blu-Ray discs
  • Looking for some advice on buring Blu-Ray discs
    Posted by John Swift on February 14, 2014 at 10:26 am
    Hi Guys, hoping somebody can help plug the gap in my knowledge here.
    I’m trying to burn off a Blu-ray disc but when testing the disc in my set top Blu-ray player & Xbox One neither device will play them (the Blu-ray burner will play the disc)
    I’ve come to the conclusion that this is down to both devices only allowing “Mastered” disc’s to play.
    My question is, if I’m burning these BD-R’s using encore then should the BD-R be recognised as a “Mastered” disc?
    a side issue I have is that encore will not burn directly to the BD writer (dreaded error 3 issue) so I’m having to burn the project to an image & then use imgburn to then transfer to disc. Hoping it’s just my workflow that may be causing the issues here
    Any help of pointers would be greatly appreciated 🙂
    Jonathan Frank replied 12 years, 6 months ago 2 Members · 1 Reply
  • Jonathan Frank
    February 15, 2014 at 10:51 pm
    I use Encore and burn with Toast, and haven’t had any problems with bluray players (and tested on a variety of models). Mac only software but if that helps…
