Activity › Forums › Adobe After Effects › Looking for Smooth Motion Blur Time Lapse Effect
  • Looking for Smooth Motion Blur Time Lapse Effect
    Posted by Rob Heller on July 2, 2015 at 6:30 pm
    Hey all,
    I’ve scoured the web trying to find how to achieve the effect that this artist has in his time-lapse drawings: https://www.youtube.com/watch?v=UpQlj21Sb3o&feature=youtu.be
    I’ve tried Pixel Motion Blur in AE, frame blending, you name it. Nothing even comes close to the fluidity of the hand motion while keeping the artwork static, in place, and in detail.
    That artist has videos that date back to 2009 so I’m thinking he may not even be using After Effects. Does anyone know what software or plugin could be used to achieve that effect? Everything else is choppy. Thanks for the help.
    Rob
    Richard Garabedain replied 9 years, 5 months ago 5 Members · 5 Replies
  • Derek Boettcher
    July 2, 2015 at 7:37 pm
    He may not be using effects at all but instead taking long exposure time lapse photographs. If you want to try to mimic with video, first start with low shutter speed, and the try using a multiple layers of effects, have your bottom most be untouched, next later use an echo effect with a fast delay and pixel blur, the a third with a Gaussian blur set to like 5+. The top most layers then should be changed to an overlay, add or softlight blending mode. Give that a try and play with the opacity and see how it works. Or just do long exposure time lapse photos
    Best,
    Derek Boettcher
    Creative Management
    BTH Media Group
    https://bthmedia.com
  • Kevin Camp
    July 2, 2015 at 9:29 pm
    i wouldn’t shoot time lapse at all. i’d shoot real time (and like derek says, as low a shutter speed as you can). then speed that up in after effects. this will give you more frames to work with and smoother motion blur (if you had the ability to shoot slow-mo it would be even better).
    simply speeding up the real time footage and using frame blending at that point will start to get you close to your example. using time effects like echo, wide time and/or time blend to create more motion blur… i’d probably try time blend first, but it functions a little differently than you’d think, so you might look into a tutorial first.
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
  • Rob Heller
    July 7, 2015 at 7:05 pm
    Thanks for the insight. I ended up contacting a local production company to get some insight and they tipped me off to the “CC Wide Time” effect within After Effects. That’s 100% what is used to get that blurred hand effect while keeping the static artwork locked in place. This works on any footage/framerate in combination with speeding it up.
  • Panos Smirniotis
    April 25, 2017 at 2:49 pm
    Pixel Motion Blur is your friend when you want to recreate motion blur in a non-low shutter timelapse ????
    Play with Shutter Angle and Shutter Samples within Pixel Motion Blur effect to find the optimal result you are looking for.
    (this is an old thread, so I reply for future reference)
  • Richard Garabedain
    April 25, 2017 at 4:14 pm
    Whatever you want to think….cc wide time may work for you but that doesnt mean 100% thats what he used.
