Activity › Forums › Adobe After Effects › Looking for Plugin effect: multi image/text layers that fly from to infinity
  • Looking for Plugin effect: multi image/text layers that fly from to infinity
    Posted by David Delouchery on September 27, 2008 at 1:42 am
    I’m looking to achieve this effect that is quite popular now where text and or images fly to or from the camera in a global/parent relationship. There is usually acceleration/deceleration involved and the images fly on a 3D path. The effect is so common that I can’t believe people are building this technique from scratch in After Effects or Motion. CoreMelt has a few effects that are similiar like Multi Swoosh but I’m not sure if that is it and it requires FCP Studio2 which I am not using yet. If anyone has a product name or if they can describe the process I’d be grateful.
    Ken Latman replied 17 years, 10 months ago 4 Members · 8 Replies
  • 8 Replies
  • Abie Silva
    September 28, 2008 at 10:37 pm
    It’s not clear what software you want to create this effect in; assuming you want to use After Effects, I believe you may be able to adjust the parameters for one or more of Digital Anarchy’s 3D Assistants plugins to create the effect you want. The link’s below…
    https://www.digitalanarchy.com/3Dassist/distributes.html
  • Abie Silva
    September 28, 2008 at 10:47 pm
    Here’s the link to the specific plugin that I meant to tell you about before. Man! I wish we could edit posts! The should be able to create the effect you mentioned.
    https://www.digitalanarchy.com/3Dassist/dplanar.html
  • David Delouchery
    September 29, 2008 at 12:04 am
    Thanks Abie,
    This looks like it will do the trick. I realize now that the layers are placed on different planes on the Z axis and then the camera flies through towards each plane. If this is the tool that they are using to create that effect that I have seen in various commercials and promo reels then great! I still feel though that there must be a easier specific plug in that achieves this effect but at least this one should make the task WAY easier. It seems though that Red Giant has bought up the plugins from Digital Anarchy but they are not ready yet for purchase. I wasn’t specific about which program I wanted to use because I wanted the plugin regardless of what program I needed to manipulate it in. I assumed that After Effects would be the defacto program anyway. I appreciate your help.
  • Nel Santiago
    September 30, 2008 at 2:16 pm
    That was a good tip Abie. David I gotta shamefully admit, a long time ago I had set up an AE project with a null object and some place holder layers (5 of ’em) and have been using that same rig over and over and over. Not the fastest, but it worked. Abie’s suggestion of the DA plug-ins is one I’ll check out next time I have to do this. Good call.
    -N
    Site:ForbiddenSky
    Blog:TVNewsBlog
    LinkedIn:Profile
  • David Delouchery
    September 30, 2008 at 3:25 pm
    Thanks Nel for your comment. I just poured over your portfolio. My question is when do you sleep? I was accused of the same thing this morning when I sent off some Photoshopped still proofs to a client at 2:30 this morning. People as busy as you seem to be shouldn’t be filling their spare time up helping out grunt drones like me but I do appreciate it. I did explore the whole null object concept before I posted but my AE skills have dulled over the past 5 yrs and the whole 3D camera motion path thing is not intuitive for me yet. I’m sure I could achieve it this way but time/budget is a luxury I don’t have for such desires. Having seen this effect so often in the past couple of years (which I still haven’t described properly or found a suitable name for it yet) I have to believe that it has to be a commercially designed plug in. Maybe it’s the Planar Distribution Assistant. I won’t know till I try it. The samples shown do not highlight the affect that is in style now. I just remembered an example. At 51 seconds into 4Ward’s demo reel they have treated the text in the fashion I’m talking about.
    https://www.youtube.com/watch?v=-vTwxJ7dQIY
    Anyways thanks again Nel.
    Dave
  • Nel Santiago
    September 30, 2008 at 5:32 pm
    Sure thing man,
    I’ll keep an eye out on this thread, in case any one pops in with a plug and play solution.
    That’s one of the pains of working in News, never really have the time to figure out the right way of doing things, just figure out one way and do it like that until we run across a better solution! ha.
    As for sleep? I sleep. But I also get up way early and try to knock out stuff like the blog and other updates before I head off to work. I work ahead. It’s hard but it’s important to me. Gotta give credit where credit is due though, I get a lot of help from my wife on researching stuff on other design ventures, she’s a producer and does a damn good job at it. But yes, it’s a lot of work.
    I’ve asked my fair amount of questions, some that never get answers, so if I have time while I’m shuffling data, or rendering fx why not pop my head in and try to help out? Designers seem to keep their “secrets” and I’ve always felt that’s a nasty way of operating. Share what you know, and others will share their knowledge with you. IMO It all balances out.
    -N
    Site:ForbiddenSky
    Blog:TVNewsBlog
    LinkedIn:Profile
  • David Delouchery
    September 30, 2008 at 6:27 pm
    N,
    You’re one of the good ones!
    D.
  • Ken Latman
    November 7, 2008 at 8:56 pm
    Andrew Kramer has a tutorial where he is walking through a very similar effect.
    Check out videoCopilot.net and the colorful universe tutorial.
    This seems pretty similar.
