Activity Forums Live Events & Streaming looking for multi image display solution
  • looking for multi image display solution
    Posted by Stephen Jackson on June 19, 2005 at 2:37 pm
    Hello All:
    Does anyone know of multi image display systems for combining several video feeds to project to plasmas and projectors?
    I only know of Evertz and I want to compare them to others.
    My specific needs are I will be combining 3 SD video feeds and some pre-built computer graphics to display to 2 plasmas and 3 projectors throughout the different clubs we’ll be in.
    I want to combine two camera views on the screen as in remote interviews and combine camera views with the pre built graphics.
    Thanks for any assistance
    Stephen Jackson
    RoaDDoggZ productions
    http://www.roaddoggz.com
    Bob Bonniol replied 21 years, 1 month ago 3 Members · 2 Replies
  • Thomas Leong
    June 19, 2005 at 3:50 pm
    Look up https://www.analogway.com for their Graphic Switcher II with their Widescreen AddOn, etc….you can download .pdfs showing example diagrams on the combination of Graphic Switcher IIs required depending on the number of screens you are projecting to. The downloads are somewhere on their site, if they have not changed their policy.
    Also, go through https://www.widescreensolutions.com/wsmainframe.html
    They use some other system. Perhaps Folsom and Extron have their own hardware options as well.
    For software options, there are AVStumpfl’s Wings Platinum with the TV/Video Module and Dataton’s Watchout with a third-party VNC software add-on. Both require a WDM-compatible video capture card installed in each of the Slave/Display PCs. Both are meant for timeline (pre-programmed/pre-planned) playback, so might not be what you want, although each has the option to program/insert a jump to any other part of timeline allowing you to program a jump to a section(s) for live video(s), and jump back to pre-prepared graphics that loop. Matter of design, and preparation.
    Thomas Leong
  • Bob Bonniol
    June 19, 2005 at 4:51 pm
    You might check out the Vista Systems Spyder, it’s a multi display controller with alot of flexibility for playback formats. I think they come base level with 4 inputs and 4 discreet outputs. It’s big brother, the Vista Montage, is the cadillac of high end multi screen control. The SPyder is supposed to be pretty economically priced. I’d look first at rental. I bet you’d find them at Scharff Weisberg in NYC, as well as at XL Video (NY,Atlanta,London,LA).
    Wings Platinum and Watchout are very flexible, and relatively cheap, but as Thomas mentoned they are timeline based, so that can be a little kinky if you are doing live, extremely variable playback scenarios (although I have made them work in the past).
    You could also consider certain of the new media servers that are sweeping the lighting world. The Hippotizer supports up to 3 discreet outputs (maybe 4 now with the new NVidia quad output cards), and High End Catalyst does up to 2 per unit I believe. You can run multiple’s of either platform for more. They also have the benefit of being controllable by the lighting console, making flexibility and timing a real snap.
    Good luck,
    Bob Bonniol
    MODE Studios
    http://www.modestudios.com
    Contributing Editor, Entertainment Design Magazine
    Art of the Edit Forum Leader
    Live & Stage Event Forum Leader
    HD Forum Leader
