Activity Forums Adobe After Effects Looking for input on arced “video wall” effect …
  • Looking for input on arced “video wall” effect …
    Posted by Tim Kocher on November 17, 2008 at 10:04 pm
    I’m hoping to get some input on how to accomplish the following look/effect:
    I’d like to have video(s) (smaller than the comp size — roughly 35%) moving along a curved (i.e. concave) surface that is facing the viewer. In other words, imagine a front projector shining video on a wall that is curved, and the video slides along this wall from left to right.
    Is there a relatively simple way to have a layer follow and bend with a curved 3D path?
    Thanks for any help.
    -Tim
    Tim Kocher replied 17 years, 10 months ago 4 Members · 8 Replies
  • 8 Replies
  • Kurt Murphy
    November 18, 2008 at 2:07 am
    Looks like a job for the remarkable 3D Layer Warp
    https://zaxwerks.com/3dwarps/index.shtml
    kurt murphy
  • Tim Kocher
    November 18, 2008 at 2:09 am
    Yeah, unfortunately, it needs to be smooth, like a piece of glass. Picture a curved holographic display — or projection onto curved glass/plastic.
  • Kurt Murphy
    November 18, 2008 at 2:54 am
    You can still use it. Just use a Transfer Mode on the curved video…. Perhaps add a moving reflection to it also….
    kurt
  • Tim Kocher
    November 18, 2008 at 2:59 am
    Sorry Kurt, I hadn’t seen your post. That was actually in response to Dave’s question about it needing to be smooth.
    Yeah, that looks like a great plug-in … except I’m about “plugin’d out” … I think I own just about every plug-in but that one. It seems like there is a way with standard After Effects operations to make that work. Or maybe with TC’s 3DStroke perhaps?
  • Paul Conigliaro
    November 18, 2008 at 2:40 pm
    Have you tried using CC Cylinder? Set up a large comp (much wider than your finished resolution), space out your video layers however you see fit. Precompose those layers and apply CC Cylinder (you might also be able to get away with an adjustment layer with CC Cylinder as well).
    Nest your larger comp inside your main comp and collapse transformations. Now you should be able to place a camera inside your cylinder to get the arced wall effect. You can either rotate the cylinder effect or the camera to get the feel of the videos sliding along the curved suface.
    CS3, FCS2
    [Note: Using Particular, 3-D Stroke, and now Form do not instantly make your designs “teh awesome.”]
  • Fernando Mol
    November 18, 2008 at 3:42 pm
    Make a new huge comp (at least 3 times your video size).
    Place your video in the center, there will be a lot of empty space around.
    Make a new comp using your standard video size (NTSC DV) and place the previous comp into a new layer.
    Apply the CC Sphere filter. Adjust the radius, lights and animate the Y rotation.
    Of course, you can experiment with the parameters.
  • Fernando Mol
    November 18, 2008 at 3:45 pm
    I haven´t seen Paul comment. Similar solution with a similar filter.
  • Tim Kocher
    November 21, 2008 at 7:20 pm
    Sorry, I’ve been off the grid for the past couple of days …
    But thanks very much to both of you, that sounds like it will work perfectly. I also had a couple of ideas that may work to enhance it as well. I’ll let you know how it works out. Thanks again!
