Activity Forums Blackmagic Design Looking for dalibration DVD/blu-ray like Disney WOW / THX Calibration Disc (UK)
  • Looking for dalibration DVD/blu-ray like Disney WOW / THX Calibration Disc (UK)
    Posted by Ben Edwards on June 22, 2012 at 11:13 am
    Hi, I am looking for a calibration DVD/blu-ray similar to the THX Calibration Disc or Disney WOW/World of Wonder Disc. I am in the UK so the US imports wont play on my mac.
    It is to be used in conjunction with an Intensity Pro.
    Ben
    Ben Edwards – Freelance Picture Editor
    https://www.funkytwig.com
    Macpro1,1 2007 6GB RAM 2*2 3Ghz Xeon
    Richard Casey replied 14 years, 2 months ago 4 Members · 7 Replies
  • 7 Replies
  • Anthony Mouchonnet
    June 24, 2012 at 7:54 pm
  • Mike Squires
    June 25, 2012 at 3:46 pm
    That’s exactly what I use to calibrate our displays. Works great.
  • Ben Edwards
    June 30, 2012 at 1:01 pm
    Do you know how to get the patterns working with the Intensity pro.
  • Mike Squires
    July 1, 2012 at 2:29 am
    Well, first off, those patterns are meant to calibrate your display. So, initially, I’d do that first.
    To check your Intensity, you really need to send color bars through it, and output that to a scope. If you don’t have a scope, send color bars through it, ingest a few seconds, and then use the software scope via Premiere or FCP to check it out.
    Make corrections via the Blackmagic Control Panel, and keep trying until you get it correct.
  • Ben Edwards
    July 1, 2012 at 11:04 am
    This is exacly what I am trying to do, calibrate the display. This is what I am trying to find out how to do.
    Also Not sure what you mean by ‘these patterns’. The ones I think I need to use are at https://www.avsforum.com/t/948496/avs-hd-709-blu-ray-mp4-calibration but the Blackmagic Media Express does not seem to play them (although it seems to import them OK.)
    Yes, the color bar test clips that come with drivers work, I don’t have a scope and am not entirely sure what one is (although I can guess). Do you have a link to somewhere that will explain.
    This sounds like a way of setting up the card for capture, this is not what I am using it for. I am using it to run a monitor so it is the monitor I am trying to set up. The monitor has lots of setting, the Intensity Pro very few.
    OK, what are the criteria for ‘correct’?
    Sorry if I am being think,
    Regards,
    Ben
  • Mike Squires
    July 1, 2012 at 7:04 pm
    What editing software do you have? I wouldn’t use Media Express, I’d use something like Premiere Pro of FCP (or you’re using a Mac). Import the video into one of those, drop it on a timeline, and then you can view the video via the Intensity.
    Without a colorimeter (like the Eye-One), you can only do basic calibration.
  • Richard Casey
    July 7, 2012 at 2:51 pm
    Not true. Disney WOW is Region ALl and will play anywhere in the world.
