Activity Forums VEGAS Pro Looking for Best rendering settings
  • Looking for Best rendering settings
    Posted by Larry Lockshaw on January 17, 2009 at 6:19 pm
    New to everything. Using a Sony Z1 camera in HD
    Sony Vegas pro 8
    Project is 12 minutes long
    (Most of my work is about 12-30 minutes long)
    Burning on NERO Vision4
    I just want to burn my projects on a DVD with the best possible resolution. I have been able to burn but I’m not happy with the
    overall quality of the final product. It is not crystal clear like I’d expect. Have been trying various changes with only mixed results. Thanks for any help you can give me!
    PROPERTIES: 720 X 480
    Lower field first
    Pixel Aspect: 1.2121
    29.970 NTSC
    Pixel format: 32 – bit (Should this be at 8 bit?)
    Best
    Gaussian
    Deinterlace method: Blend fields (Is this right?)
    RENDERING: Main Concept mpeg-2
    Template: DVD NTSC video stream (I’m not using DVD
    ARCH yet. I’m using NERO Vision4) Maybe this is my
    problem. NERO has always worked great for me but am
    missing out by not using DVD ARCH?)
    What is the best template to be using for a 16:9 DVD?
    NERO does work with the AUDIO rendered on a seperate
    AC3 file. Is there an advantage of doing this?
    CUSTOM: BEST
    Output type: DVD (Should this be MPEG-2 or HDV?)
    29.970
    Aspect Ratio: 16:9 ???
    720 x 480
    I frame 15 B frames 2
    Lower field first
    Video quality 31 High
    Variable Bit Rate max 9,500,000
    avg 6,000,000
    min 192,000
    Audio: Include audio stream
    Can you tell I’m messed up? I make myself laugh because I haven’t a clue how bad off I really am.
    Thanks for any help. -Larry
    Larry Lockshaw replied 17 years, 8 months ago 4 Members · 7 Replies
  • 7 Replies
  • Corey Whitley
    January 17, 2009 at 9:03 pm
    Not sure if I can help, but I will try.
    Did you say you are shooting in HD? Is it native 16:9? If so you may wish to change your project properties to HD 16:9. Also I would render using a default HD setting instead of 720 x 480.
    Not sure if this will improve things but it seems like you may not be using the right settings for your export.
    Corey Whitley
  • John Rofrano
    January 17, 2009 at 10:13 pm
    I set my project up using the NTSC DV Widescreen (720×480, 29.970 fps) setting and I render with the MainConcept MPEG-2 type using the DVD Architect NTSC Widescreen video stream template and render the audio separately as AC-3 and I have no issues with the DVD output from my Sony Z1. No tweaking or anything. Just use the defaults templates provided by Sony. Nero should be fine with this and not need to re-encode or anything.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Terry Esslinger
    January 17, 2009 at 10:29 pm
    And John, this is for HD (720×480?)
  • John Rofrano
    January 17, 2009 at 11:04 pm
    This is for taking the 1440×1080 HDV from my Sony Z1U down to an NTSC 720×480 Widescreen DVD.
    ~jr
  • Larry Lockshaw
    January 18, 2009 at 5:08 pm
    Thanks everyone for the help.
    John Rofano – I tried your recommendations and was confident it was the magic bullet but I was quite surprized when the rendered product was poor in quality.
    Corey Whitley recommended the default HD settings with HD 16:9 and that was much better however, I’m still not there. everything is not as sharp as it should be. Even the type graphics have a fuzzy
    soft look.
    Any recommendations to try to narrow down the problem?
    The native footage is 16:9 in HDV.
    I’ll be gone for a few days but look forward to getting back to hear any ideas. Thanks in advance!
  • John Rofrano
    January 18, 2009 at 6:20 pm
    > Even the type graphics have a fuzzy soft look.
    By “type graphics” do you mean text? Would this be text from generated media? What project properties were used when you added the generated media? This is why I suggested using a DV Widescreen project. I have seen text get blurry when I create it in an HD project and render as DV Widescreen. I now create my text at DV quality and I like the output much better because it’s not getting resized from HD down to DV.
    ~jr
  • Larry Lockshaw
    January 19, 2009 at 1:45 am
    Thanks John, I’ll try that out.
