Activity Forums Apple Final Cut Pro Legacy Looking for a ‘TV look’ Plug-in
  • Looking for a ‘TV look’ Plug-in
    Posted by Godfrey Pye on September 9, 2005 at 1:21 am
    Have any of you kind folks out there had experience with – and therefore can you recommend an FCP plug-in that will be placed on an image in a scene that has been reduced and then fitted into a TV set. Basically I wish to add lines to an image, as if it was material being viewed on a TV set.
    Thanks in advance.
    Godfrey Pye
    Mulholland Bays – in the Hollywood Hills
    Godfrey Pye replied 20 years, 11 months ago 5 Members · 5 Replies
  • Shane Ross
    September 9, 2005 at 3:01 am
  • Jeremy Garchow
    September 9, 2005 at 3:05 am
    https://tinyurl.com/cyvpy
    This tutorial will teach you to modify the v wipe transition and make a 100 band v wipe. Once you have made that v wipe, all you have to do is modify that start and stop positions of the transition to where you like it (say start at 89% and end at 89%) and then you’ll have it.
    Good luck
    Jeremy
    G5 Dual 2Ghz <> 4GB RAM <> FCP 4.5 <> Kona 2
    ATTO 42XS <> Huge Systems 1.25 TB 4105 Fibre
  • Andy Mees
    September 9, 2005 at 3:55 am
    Hi Godfrey
    if you’re budgeting for a set of effects then take a look at https://www.profoundeffects.com/products/camerapov/
    their scanline plug looks good
    cheers
    Andy
  • Matthew Brunn
    September 9, 2005 at 4:43 pm
    Try their “Video look” plug-in
    https://www.kafwang.com/EUREKA/EurekaMain.html
    Hope this helps-
    Matthew
    Dual 500 G4
    OSX 10.3.5
    Ram 1.38
    FCP 4.5/AE 6.5/DVDSP3
  • Godfrey Pye
    September 10, 2005 at 1:35 pm
    Thanks guys, in the end I went with Matthew’s Eureka plug-ins.
    I am too lazy/in too much of a hurry for the two DIY options suggested – and I couldn’t find Andy’s suggestion that would work with FCP.
    Thanks again.
    Godfrey Pye
