Activity › Forums › Adobe After Effects › Looking for a perspective plugin
Posted by Nutsyuk on July 9, 2007 at 3:07 pmIm looking for a controled point A [left] to point B [right] perspective distortion plugin with central focal shift and apature settings for each point.
Iv been trying to use the meshwarp tool but im finding it to be a pain in the arse with the breazer handels getting in the way.
Im trying to make laser beam styled effects for a project im currently in and I really need a simple point to point distortion tool like the one i discribed.
Does anyone know of such a plugin. Or anyone know how I can get some one to build this simple plugin? I may be willing to commision some one to build this plugin for a cheap price but I need to talk to my producer first.
I look forward to hearing from anyone 🙂
Simon
Nutsyuk replied 18 years, 11 months ago 4 Members · 10 Replies -
Mike Clasby
July 9, 2007 at 5:14 pmHave you checked out the new PhohtShop CS3 to AE CS3, perspective to AE 3D? For now, Andrew has a hot tut here (coing soon o the Cow, I’m sure):
https://www.videocopilot.net/tutorials.html
39. 3D Vanishing Point June 27, 2007
and these might be useful, or not:
38. 3D Camera Projection 2 June 27, 2007
37. 3D Camera Projection June 25, 2007
Nutsyuk
July 9, 2007 at 6:01 pmIm still in 6.5 and cs2
But when i say perspective i dont simply mean a rotating card… Im trying to make laser beam effects. I have my laser beam texture all ready but I want to setup a point to point left to right sort of control on the layer with apature settings for each point so thick at point A and thin at point B. I have tyred it with the mesh distort but its fiddly and I have ALOT of lasers to do.
Nutsyuk
July 9, 2007 at 6:59 pmNo its not.
I need a distortion tool like mesh warp. But without the mesh or handles. point to point like beam but only distorting. With the ability to set the apature at each end and focal shift.
I dont want to use the beam tool as the effect is too simple the quality is crap. I already have a beam effect texture made. Its perfect the producers have already locked it down. I need some thing that can manipulate this layer thats all…
Darby Edelen
July 9, 2007 at 7:34 pm[NutsyUK] “With the ability to set the apature at each end and focal shift.”
I was going to suggest you look at Distort>Corner Pin, but if you’re getting this involved with it you might want to just bite the bullet and make it 3D with DOF.
If you can’t find any 3rd party plugs to do this the alternative would be setting up one hell of a complicated Animation Preset using Nulls, Corner Pin and Lens Blur… at which point you’ll probably hate yourself for not just doing it in 3D to begin with.
Darby Edelen
DVD Menu Artist
Left Coast Digital
Aptos, CA -
Nutsyuk
July 9, 2007 at 8:11 pmlol hmm if its going to be this crappy might as well stick with mesh smooth and all its problems
Nutsyuk
July 9, 2007 at 8:26 pmOhh actualy corner pin is alot easyer 😀 didnt notice that one before
David Bogie
July 9, 2007 at 11:24 pm[NutsyUK] I”m looking for a controled point A [left] to point B [right] perspective distortion plugin with central focal shift and apature settings for each point.”
Glad you found something as simple as Corner Point.
I read your thread several times and I still have no idea what the visual effect youre’ trying to accomplish. I don’t know how you would use an “apature” as a control on such an effect. You might mean “aperture” but that would imply depth of field control is on your list of distortions. Is this a lens-like effect? Like looking through a piece of glass or a lens?
Look into Compound Effects like Compound Blur. If you can create a grayscale image that has a and b points you can control the amount of blur and distortion it imposes on underlying layers.
bogiesan
Nutsyuk
July 10, 2007 at 1:12 amI ment apature as in size. not blur. tbh I would still like to have the plugin im looking for but for now 3 point will have4 to do
Nutsyuk
October 22, 2007 at 1:24 pmActualy thinking about it… The AE Beam generator is really close to what i want.
I want a distortion plugin that uses the same controls. But instead of using a simple beam its using a detailed beam sequince that i have made.
Does anyone know of a pluging like this?
I did end up trying that 4 corner one but its still a pain in the arse :/ as some of the shots are really tight one end being a pixel or two in size.
Nutsyuk
October 22, 2007 at 1:25 pmActualy thinking about it… The AE Beam generator is really close to what i want.
