Activity Forums Adobe After Effects Look at constraint in AE
  • Look at constraint in AE
    Posted by Deeps_n on September 17, 2006 at 5:15 am
    Hi!
    is it possible to link all my 3d layers in AE with a camera, so that they always face the camera, Similar to the LOOK AT constraint in 3ds max.
    Sanspoof replied 20 years ago 2 Members · 1 Reply
  • Sanspoof
    September 17, 2006 at 9:14 pm
    Yes, I know that it is possible.
    There is an auto-orient button/property somewhere.
    Ah, found it. Have the camera you want to use actice (selected as the view you see in the monitor window). Then select the layers you want pointed to the camera and hit Ctrl+Alt+O (or layer>transform>auto-orient).
    Play around with that and it should do what you want.
    peace,
    Michael
