Activity › Forums › Adobe After Effects › Long shadow
  • Long shadow
    Posted by Chris Brady on April 26, 2017 at 11:58 am
    I am trying to re-create the style of long shadow seen in the video below:
    https://vimeo.com/174142915
    I need to supply the final After Effects file to the client so can’t use any plugins they won’t have, unless I can apply the Expression Universalizer to the final file before supplying.
    I have tried the Long Shadow plugin. However this does not give me the same level of blurriness that is shown in the example video.
    Even if it is a long winded manual way of applying this effect, what would be the best way of doing so? Any ideas would be greatly appreciated.
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Richard Garabedain replied 9 years, 5 months ago 2 Members · 1 Reply
  • Richard Garabedain
    April 26, 2017 at 2:56 pm
    Its probably an actual shadow created by an actual light. with a high difuusion shadow. Might have to be in ray trace 3d mode under composition settings
