Activity › Forums › DSLR Video › Long-range remotely controlling the video on a Canon DSLR with EOS Utility
  • Long-range remotely controlling the video on a Canon DSLR with EOS Utility
    Posted by Ronan Donovan on April 29, 2014 at 7:40 pm
    Greetings,
    I’ve run into an issue with remotely controlling the video on a Canon DSLR (5D2 and 7D) while maintaining EOS Utility. I need 150+ft range and USB drops off after ~30ft. I’ve tried USB to ethernet adapters since I was told ethernet doesn’t drop off, but that hasn’t worked yet – I was later told you would beed a network router for this to work? Does anyone know of a solution for wired control of a Canon DSLR so that the control through EOS utility is still functional.
    I have solutions for wirelessly triggering video with a pocketwizard setup, but I lose two very critical things; exposure control control and media download.
    The concept is to have a camera rigged in a location where repeated visits isn’t an option – so exposure control and media download are key.
    I’ve read that the Canon wireless transmitters will also maintain the functionality of the EOS Utility – does anyone have experience with that? What do folks with these RC helicopters do for remote control of video? Probably a much bigger budget than I have…
    Thanks in advance for suggestions and advice.
    -Ronan
    Ronan Donovan replied 12 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
