Activity Forums Adobe Premiere Pro Long MTS files (AVCHD) causing freeze/hang
  • Long MTS files (AVCHD) causing freeze/hang
    Posted by Randy Mcwilson on June 10, 2012 at 11:08 pm
    If you are one of the many thousands experiencing freezing, hanging or other poor performance when working with long/spanned MTS files (AVCHD) then please take one minute and visit the Adobe Bug report. They are aware of this, but need your voice to move this to the “front burner” for their next bug fix:
    https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
    (This is Adobe’s bug report page)
    Send Adobe something like “Long/spanned MTS (AVCHD) files cause hanging/freezing”
    also, most are also complaining about “Audio RE-conforming” each time one of these projects opens, maybe send that too.
    They respond to volume, so let’s “turn up” the volume.
    Eternity…don’t miss it for the world.
    Todd Kopriva replied 13 years ago 5 Members · 5 Replies
  • Tero Ahlfors
    June 11, 2012 at 7:52 am
    Well that’s AVCHD for ya. It’s a goddamn horrible codec and I wish people wouldn’t use it.
  • Shane Ross
    June 11, 2012 at 8:51 am
    This is why I prefer transcoding to working native. For many codecs.
    Shane
    Little Frog Post
  • Chris Walsh
    June 11, 2012 at 4:31 pm
    I’m surprised it plays the MTS files as well as it does…I’ve learned to be patient and not go too crazy with fast shuttle and reverse.
    I will add my voice, but overall I’m ok with a little AVCHD lagginess for what I save on disk space and transcode time.
    For bigger/crucial projects I might transcode to gain some performance back.
    My biggest complaint is file relinking — it’s so poor, it makes native MTS very dangerous unless I’m careful with file naming on import. If I don’t, I have to try to remember which one of the the fifteen or twenty 00003.mts files I used in a particular bin of a project. And PPro will happily link to any of them, correct or not.
    Chris Walsh
    http://www.musicfog.com
    Silver Spring, MD
    Final Cut & AVID MC5
    Former Windows User and edit* lover
  • Randy Mcwilson
    June 29, 2012 at 5:17 pm
    Chris:
    The problem is that Adobe CS5 and CS5.5 worked PERFECTLY with .MTS spanned files (where it starts new .MTS files every 4GB of data) but with the release of CS6 it cannot handle the spanned clips.
    If you have short, non-spanned MTS then CS6 works fine, but for wedding/event videographers, this is a real issue.
  • Todd Kopriva
    August 15, 2013 at 1:16 am
    The Premiere Pro CS6 (6.0.4) update fixes the spanned AVCHD clip bug: https://bit.ly/DVA_updates
    After Effects team blog
