Activity Forums Blackmagic Design Long HDMI cable to Intensity Pro and CS4.2 workable?
  • Long HDMI cable to Intensity Pro and CS4.2 workable?
    Posted by William Meese on November 29, 2009 at 9:44 pm
    I’m building a small (10’x10′) webcast studio for a client, feeding Premiere Pro on Windows. I’m planning to use a Panasonic AG HMC40 camera, feeding HDMI over a 30 ft run to a BMD Intensity Pro card in the edit system, capture and edit as HD Motion JPeg 1280×720 on an internal drive.
    Most importantly, how is the Intensity card working with CS4.2? I see in the forums that there were delays w/ drivers earlier in the year.
    Also, anyone have experience w/ long runs of HDMI? I’ve got a Laird HDMI repeater in the budget–is that needed?
    720 Jpeg looks to be about 18 Gigs/hour, or about half again as much as DV. Can I expect one fast internal drive to handle that? Two striped drives?
    Lastly, with footage shot in the field, how is CS4 with AVCHD files? Would another camera brand/format be more reliable?
    Any advice or comments–especially if I’m missing something big, here. I’ll also cross-post in the Premiere Pro forum. Thanks!
    William Meese replied 16 years, 9 months ago 3 Members · 7 Replies
  • 7 Replies
  • Joshua Helling
    November 30, 2009 at 6:42 pm
    Intensity as well as all of our boards are now working quite well with CS4. It was a rough start for sure, but we are in a good spot now.
    As for a 30′ run of HDMI, that could be a problem. But the repeater should work, but we haven’t tested that cable so can’t confirm. But I would guess it will work. I would check it with a shorter run first, to make sure all is working then put the longer cable on and test it.
    Sincerely,
    Joshua
    Director of Support
    Blackmagic Design Inc.
  • William Meese
    December 1, 2009 at 7:22 pm
    Wow, I didn’t expect an answer straight from the horse. Since this is a purchase for a client, I feel more confident going with the Intensity card. Not really possible to test the HDMI beforehand, which is why I’m asking if anybody’s doing that.
    Thanks for the response!
  • Joshua Helling
    December 1, 2009 at 10:10 pm
    I’ve used cables in excess of 20 feet myself personally (in my lab as well as at shows). But for those longer runs I always buy the more expensive cables.
    The ones i’ve used have all been passive. But again…I have good feelings about a proper HDMI repeater cable. So you should be good.
    Sincerely,
    Joshua
    Director of Support
  • William Meese
    December 2, 2009 at 7:38 pm
    And my cross-post on the Premiere Pro forum gave me another possible source for good cables. Thanks, Joshua.
  • Joshua Helling
    December 3, 2009 at 1:07 am
    Cool!
    Sincerely,
    Joshua
    Director of Support
  • Jason Gragilla
    December 4, 2009 at 10:51 am
    Hey William,
    Just to reinforce what Joshua is saying I have been using my Intensity Pro with a powered repeater and 30′ HDMI cable (spec 1.3a) on a daily basis for about the last 6 months and have yet to run into a single issue.
    – Jason
  • William Meese
    December 5, 2009 at 7:13 pm
    That’s good to hear. Thanks!
