Activity Forums Adobe Illustrator Long File save time in Illustrator
  • Long File save time in Illustrator
    Posted by Ace Billet on October 16, 2005 at 11:51 am
    When I’m saving a file in Illustrator CS (OS X), it takes a lot of
    time to save the file. There is an EPS pic in the document.
    Is there a way to make saving files quicker ?
    It reeeeaaaally hurts my workflow.
    cheers
    ace
    Seth Olson replied 20 years, 11 months ago 2 Members · 1 Reply
  • Seth Olson
    October 20, 2005 at 1:43 am
    What is the resolution for the EPS image? Does it take as long to save if you remove the image? Perhaps you could work with a JPEG version during the work flow and replace it once you are done? What are you saving as?
