Activity Forums Apple Final Cut Pro Legacy Long file import issue
  • Long file import issue
    Posted by Peter Groom on April 1, 2014 at 2:35 pm
    Hi
    I am having trouble importing a Long Motion JPEG A type into FCP. I find that if i create a short file, it goes into FCP 6 fine, but a long one (2 hours and more) brings up a “file not recognised” error.
    Any suggestions as to
    1) why
    2) what i could do about it
    or
    3) what file type I could make that WILL go in. It needs to be smaller than pro res (which goes in fine) and I found that motionj peg was 1/10th size to perfect/
    Any thoughts much appreciated.
    Peter
    Post Production Dubbing Mixer
    Peter Groom replied 12 years, 5 months ago 2 Members · 2 Replies
  • Shane Ross
    April 1, 2014 at 5:02 pm
    FCP doesn’t edit that format natively…you should be converting it to a codec FCP does work with, like ProRes.
    Shane
    Little Frog Post
  • Peter Groom
    April 2, 2014 at 6:18 pm
    Hi thanks for that.
    The hard drive is ntfs format and works fine on my Mac with fcp.
    If that file type us t supported what else apart from pro res is support ed. Pro res seems overkill as it’s just a PowerPoint t recording .
    Peter
