Activity › Forums › Adobe After Effects › Lomography Look ?
Lomography Look ?
Posted by Roboday on October 25, 2005 at 5:15 pmHi there guys, Im trying to achieve a “lomo” look to some footage, however im strugling with the tone’s, ect.
Its almost like “cross processing”.
However the 55mm one isn’t controlable.Im trying to get looks like these:
https://shop.lomography.com/beyondevenmored…=AD_11285762081
https://shop.lomography.com/beyondevenmored…=AD_11290025231
https://shop.lomography.com/beyondevenmored…=AD_11285129581
https://shop.lomography.com/beyondevenmored…=AD_11277210491
https://shop.lomography.com/beyondevenmored…=AD_11271647291
https://shop.lomography.com/beyondevenmored…=AD_11271647601
https://shop.lomography.com/beyondevenmored…=AD_11262205421
Many thanks for any tips\hints.
Roboday replied 20 years, 11 months ago 6 Members · 11 Replies -
Roboday
October 25, 2005 at 5:25 pmOk, for some reason those links have been shortened.
[Obviously a vignette is easy enough].https://shop.lomography.com/beyondevenmoredeluxe/lomoaddicts/pop.php?id=AD_11262205421
https://shop.lomography.com/beyondevenmoredeluxe/lomoaddicts/pop.php?id=AD_11271647601
https://shop.lomography.com/beyondevenmoredeluxe/lomoaddicts/pop.php?id=AD_11271647291
https://shop.lomography.com/beyondevenmoredeluxe/lomoaddicts/pop.php?id=AD_11277210491
https://shop.lomography.com/beyondevenmoredeluxe/lomoaddicts/pop.php?id=AD_11285129581
https://shop.lomography.com/beyondevenmoredeluxe/lomoaddicts/pop.php?id=AD_11290025231
https://shop.lomography.com/beyondevenmoredeluxe/lomoaddicts/pop.php?id=AD_11285762081
Roboday
October 25, 2005 at 7:16 pmHey Dave, Im talking about using After Effects with shot HD footage [maybe I should have said that to start with].
Not stills.TIA.
Jay Blanchard
October 25, 2005 at 8:20 pmHiking up the contrast and saturation would be a good start; crush the blacks & add a fake fisheye effect.
Roboday
October 25, 2005 at 8:53 pmyeah, i’ve already been playing with those, but im not getting those looks of weird colouration across seemingly random areas, not yet anyway with just those 2.
If anyone gets close, dont be shy to show us. -
Steve Roberts
October 25, 2005 at 9:04 pmI’d add a layer with the ramp effect applied, tinted in some fashion with a funky transfer mode over the hue/sat effected footage. If you need the same thing randomly applied across the frame, try a fractal noise layer applied the same way.
You might need to change those layers on every cut, to make the effect less noticeable.
Steve
Annaël Beauchemin
October 26, 2005 at 12:07 am[RobOday] “but im not getting those looks of weird colouration across seemingly random areas”
Basicaly, use curves to add contrast in different channels (RGB). To add contrast, you must do a S shaped curve. You can add global conrast to the RGB channel and then fiddle with R, G or B separately. I put this filter on an adjustement layer.
You then need to add a black halo using a radial ramp on a solid layer set to multiply. Then another, smaller, set to add, for the central bleach. You put those two layers between the source picture and the adjustement layer.
a composition is worth 1000 words:
https://junktape.com/lomo_test.zip
Roboday
October 26, 2005 at 12:18 am“a composition is worth 1000 words”
I certainly agree, however your explaination was good too 🙂
I look forwards to checking out your file.
Derrick
October 26, 2005 at 5:11 amThanks for including a sample file, this always makes it easier for us novice guys to learn the techniques!
– Derrick
Milesl2@mac.com
October 26, 2005 at 6:37 pmHere’s another one that adds a slight “film look”. Apply Hue Saturation to an adjustment layer at the top of the comp and desaturate. Apply curves and adjust the individual R, G, and B to make the straight line look like a jagged line (maybe 8 or so points each?). Apply another Hue/Saturation underneath the curve effect and adjust saturation back up. Go back to your adjusted curves and fix to your taste (ie more green, less red, etc) Add salt and serve.
