Activity › Forums › Apple Final Cut Pro Legacy › Log&Transfer SD footage w/5D – why won’t it work?
  • Log&Transfer SD footage w/5D – why won’t it work?
    Posted by Alex Denver on June 27, 2010 at 11:38 pm
    I searched but couldn’t find the answer I’m looking for.
    I shot a project at 640×480 at 30fps, but cannot Log & Transfer these files into FCP7. The files do not show up in the L&T window, and when I try to drag them in, it says the media is unsupported and/or file structure is wrong.
    What are the alternative ways to handle these files in an organized way?
    Is there any way to L&T these directly from the CF card?
    Any help would be much appreciated.
    Alex Denver replied 16 years, 3 months ago 2 Members · 2 Replies
  • Jeremy Garchow
    June 28, 2010 at 3:06 am
    Not sure if the ‘SD’ size is supported, but you did download the Canon plugin, correct?
  • Alex Denver
    June 28, 2010 at 12:11 pm
    Yup, downloaded the E-1 plugin, but for some unknown reason it does not support SD footage.
