Activity Forums Apple Final Cut Pro Legacy Log/Transfer clipping RED files?
  • Log/Transfer clipping RED files?
    Posted by Aaron Neitz on July 24, 2009 at 2:21 am
    I’m too slammed to troubleshoot! One of my editors is Log/Transferring in some RED files and it’s inexplicably truncating some of the files. i.e. 40 seconds of footage simply doesn’t come over.
    is this a known problem? I’ve never heard of it.
    everything is super straight forward. No in/outs set on the footage, etc…
    Robert Due replied 17 years, 1 month ago 3 Members · 3 Replies
  • Russell Lasson
    July 24, 2009 at 2:39 am
    Could be a dropped frame in the footage. Try opening the clip up in REDAlert and transferring it that way. Also look at the RED forum as this has been discussed. Don’t remember how it turned out.
    -Russ
    Russell Lasson
    Colorist/Digital Cinema Specialist
    Color Mill
    Salt Lake City, UT
    http://www.colormill.net
  • Aaron Neitz
    July 24, 2009 at 3:12 am
    thanks russell,
    found the thread. there was no solution…. we’re going to redrushes for the remainder. figure it out later
  • Robert Due
    July 24, 2009 at 3:00 pm
    Aaron,
    Have you been trying to view clips and log and transfer at the same time? I have found that if you let the log and transfer process finish (uninterrupted) then clips will not be truncated. I have on occasion, manually set ins and outs on each clip before doing the log and transfer. This seems slow, but it has worked for me in the past.
    Good luck.
    Robert Due
    Editor / Colorist
    INDEPENDENT EDIT
