Activity Forums Adobe After Effects Expressions logo into dripping blood/water
  • logo into dripping blood/water
    Posted by Walkinginspace on August 7, 2006 at 1:30 am
    I have a logo that reveals on then stays on screen for 2 seconds, then I need it to melt/slide/drip off the screen. I’ve tried particle, liquify and still can’t get the right look. Does anyone have any clues or ideas on this or better yet a past project that this was done in? Thanks for any help!
    steve
    Sam Moulton replied 20 years, 1 month ago 5 Members · 5 Replies
  • Michael Duff
    August 7, 2006 at 1:41 am
    maybe you could try Mr. Mercury – I haven’t used it before so I can’t help you too much, but do a search for it in the archives
  • Walkinginspace
    August 7, 2006 at 1:57 am
    mr mercury seem to just spurt out from a single point, not allow a exist frame(logo) to be turned into it….
  • Mylenium
    August 7, 2006 at 5:19 am
    Na,you won’t have much luck with anything synthetical. Get yourself some stock footage of dripping paint or create some yourself (white wall paint on black paper works well), then use bits and pieces of this as mattes in combination with other masks.
    Mylenium
    [Pour Myl
  • Mike Clasby
    August 7, 2006 at 7:56 am
    This isn’t bad.
    CC Scale Wipe (Transition)
    First drop then center down below the Logo: Set a keyframe
    Stretch 10 (your choice, tweak later): Set a keyframe
    Direction 180: Set keyframe
    Now down the time line, move the center to above the Logo, wiping the Logo off the screen
    Note: If your Logo is a smaller layer than the Comp, you may need to Image Control>Grow Bounds and add a few hundred pixels. Slide Grow Bounds above the Scale Wipe.
    Roughen Edges (Stylize)
    I Like Spiky
    Border: 0 to start = no effect, crank it up down the line, to add irregularity to the melting edges.
    Complexity: 1 seems better than more
    Tweak to taste
    CC Glass (Stylize)
    Height: 0 to start, then up to 30 or 40 down the line
    Most of the times this gives a glassy texture like melting, but some color schemes don’t seem to work well, you choice.
    Also to give it a little flowing Rivulet action
    CC Bender (Distort)
    Amount 0, but add wiggle expression: wiggle (2,8)
    Top: Set at bottom of logo
    Bottom: Set to off bottom of Comp
    Type: Marilyn
    or better yet for the Bender see Aharon’s tuts on Displacement Maps (Click his head at top).
    Oh, yeah, If there a big flat bottom, like a letter D or L, then the sheeting action of it falling like a curtain spoils the look, so if you want dripping more try a rectangular or wedge mask to split the bottom. It can get tricky to adjust since the Glass above blobs things out, but put one there (Invert) and play with the mask expansion until it looks right.
  • Sam Moulton
    August 7, 2006 at 9:27 am
    i used this technique once. found it a long time ago when I was searching for cool projects
    https://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=2&postid=312431&archive=T
