Activity › Forums › Adobe After Effects › logo field
logo field
Posted by James Johnson on July 21, 2010 at 1:33 pmHi all,
I have about 60-70 company logos in a photoshop file (all seperate layers) and was wondering, what would be the simplest way to animate them in AE. I was thinking of them being in like a “starfield” in 3d space coming closer to (and maybe fly by) the camera. what would be the best way without animating each one individualy? Thanks in advance for the tips!
James Johnson replied 16 years, 2 months ago 4 Members · 7 Replies -
James Johnson
July 21, 2010 at 3:26 pmSadly I do not. Would i be able to do it with particle world or any other default AE effect?
James Johnson
July 21, 2010 at 4:42 pmOk so you’re saying with Particular I would be able to change each individual particle into one of my 70 logos allowing all 70 to be on screen in 3d space? If so great, and I will definetly look into buying Particular. Any suggestions on tutorials for such a thing?
Michael Szalapski
July 21, 2010 at 5:37 pmYou could arrange all of the logos in a grid in a precomp and then use Card Dance to put them in 3d space.
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Jeremy Allen
July 21, 2010 at 6:44 pmI was thinking along the lines of Michael’s Card Dance solution. The particle trick will certainly make it easy to distribute the logos in 3D space, but I’ve found it difficult to show ONLY one of each logo. If that’s not a big deal to you then go for it.
The basic idea of using custom particles is to have a composition wherein each logo only takes up one frame. So frame 1 would be logo 1, frame 2 is logo 2, etc.. Then you use that composition for your custom particle. Under the Custom twirl-down, set Time Sampling to random – still frame.
Hope this helps..
8core MacPro, 3.0 GHZ, 10GB RAM, OSX 10.5.6C4D 11.5
AE CS3
FCP 6.0.1 -
Chris Wright
July 21, 2010 at 6:46 pm -
James Johnson
July 22, 2010 at 3:13 pm -
James Johnson
July 22, 2010 at 6:36 pmProblem Solved! I just had to have the X and Y positions linked to themselves instead of the gradient. Still wishin I had Trapcode Particular..looked alot easier…(sigh)
