Activity Forums Adobe After Effects Expressions Logo at the end of an elastic string
  • Logo at the end of an elastic string
    Posted by Corbin Gross on August 5, 2010 at 10:25 pm
    I’d like to have a logo fall on screen hooked to an imaginary elastic string. I don’t actually need to see the string, I just want the behavior.
    I’ve got the logo animated on, from top to bottom, with Dan’s Jack-in-the-box expression and it looks pretty good so far. But I’d like this single string (theoretical string, you can’t see it) to be attached in such a way that the logo will rock from side to side and pivot and twist a bit.
    Imagine a piece of foam core with a grommet/rivet on the top, center. if you had about 5 feet of string and let the thing fall it would kind of wiggle and bounce. You know.
    I’m thinking it will need to be some combination of decayed wiggly bouncy thing applied to the orientation or XYZ but I can’t quite wrap my brain around it.
    Thanks for the help all.
    Corbin Gross replied 15 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
