Activity Forums Adobe After Effects Logo animation!
  • Logo animation!
    Posted by Justin Wood on July 8, 2011 at 9:02 am
    Hello,
    Hopefully this should be an easy question to answer…
    I am relatively new to after effects but I have been asked to animate a logo.
    The link to the old SD version is below…it will be the same but just needs updating so it is HD.
    https://www.youtube.com/watch?v=dOdBiaZuPmA
    My plan of action is…
    1. Mask the logo and animate the mask so the logo appears at the right rate
    2. Create a spark and key frame it to follow the unveiling of the logo
    I am reasonably confident doing this, the only thing I am unsure of is how to make the logo yellow as the spark ‘writes it out’ and then fade back to red? Another animation behind the logo? Any advice on how to achieve this would be greatly appreciated! I have googled but I was unsure what to google?!?
    Justin
    Justin Wood replied 15 years, 2 months ago 2 Members · 2 Replies
  • Tudor “ted” jelescu
    July 8, 2011 at 1:59 pm
    You can also create an adjustment layer with an animated mask that is feathered. The mask should travel with the light/spark. On the adjustment layer you can apply a Hue?Saturation filter that can change the red to a bright yellow. You can animate the properties of the plugin as well as the Mask expansion to give the impression of flicker.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Justin Wood
    July 8, 2011 at 4:06 pm
    Thankyou very much, your advice worked amazingly and i am very happy with the result 🙂
