Activity Forums DaVinci Resolve Logitech g13 and Contour Shuttle combo?
  • Logitech g13 and Contour Shuttle combo?
    Posted by Saul Budd on May 6, 2013 at 1:33 pm
    Hi All,
    Slightly different topic from this thread : https://forums.creativecow.net/thread/277/2690#2934 so i thought it better to start a new thread and cross-post.
    Has anyone tried using the g13 and a contour shuttle pro (or Shuttle Xpress) together? I’m about to order both, but I just want to check there’s no kind of conflict driver/software wise. Someone in the above thread mentions having a shuttle and purchasing a g13, but it’s not clear if they are using them in conjuntion.
    I’m switching to DaVinci from Color, and of the two facilities I’ll mostly be working at, one has the Tangent Elements panels (fine, but I need to map a whole load of extra keys), and one has a Euphonix MC Color (again, fine, but no jog control and having to press two buttons to go forward/backward a clip is not ideal!). I’d probably also want to map buttons even for some functions which are on both panels, so that it’s easier to switch between the two interfaces.
    Saul
    Saul Budd replied 13 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
