Activity Forums Adobe After Effects Logical problem / Position, Scale and Speed
  • Logical problem / Position, Scale and Speed
    Posted by Wilhelm Hagberg on July 23, 2009 at 6:01 am
    Hi
    I’m animating a row of fishes that are swimming along a spiral shaped path. The fishes become smaller and smaller as they are approaching the center of the spiral. In fact I have only animated one fish, and then duplicated the layer 20 times and sequenced the layers.
    Now my problem is that i want the distance BETWEEN the fishes to be constant, that is, each fish should bite the tail of the fish in front of him. I don’t know how to achieve this. Right now the distance between the fishes increases as they become smaller. Any ideas?
    best-
    Wilhelm
    Wilhelm Hagberg replied 17 years, 2 months ago 2 Members · 2 Replies
  • Ben Rollason
    July 23, 2009 at 12:17 pm
    If you made the spiral a 3D helix instead, then if placed correctly, it would look like a spiral to the camera. The fishes would get smaller as they move away from the camera – due to perspective, but the distance between them wouldn’t change.
    Otherwise you’ve got a nasty bit of expressions work on your hands, or a lot of manual tweaking.
    There’s plenty of tutorials about getting things to follow 3D paths in After Effects.
    One way would be to attach each fish to a null. Then rotate the null around its z-axis while at the same time moving it away from the camera along its z-axis. Then duplicate this arrangement up x times and offet them along the time line to get the desired distance.
    -Ben.
    http://www.benrollason.com
  • Wilhelm Hagberg
    July 23, 2009 at 7:26 pm
    Hi and Thanks!
    The fish move in relation to a 2D drawing, so the 3D approach is difficult here (I think tweeking the paths in 3D space would take too long). Any other ideas for how to do this ?
    Here is an image showing what I’m trying to do :
