Activity Forums Adobe After Effects Expressions Logical Operator "Or" and Drop Down Menus
  • Logical Operator "Or" and Drop Down Menus
    Posted by Christian Simpson on December 8, 2022 at 5:34 pm
    Hey Friends,
    I am trying to adjust the opacity of a layer using a if/then expression and drop down menus. I would like it if multiple drop down menu options were selected it would adjust the opacity of a layer.
    So basically if I select either option 3 or 4 in my drop down menu it will return 100% opacity, if neither of those are selected it returns 0%. I’ve tried to write this as many ways I know how and nothing seems to work. Any thoughts?
    if(comp("blind_resume_template").layer("blind_resume_control").effect("Sport")("Menu") == 3) || (comp("blind_resume_template").layer("blind_resume_control").effect("Sport")("Menu") == 4)
    {100} else 0;
    Dan Ebberts replied 3 years, 9 months ago 2 Members · 3 Replies
  • Dan Ebberts
    December 8, 2022 at 5:45 pm
    This should work:
    m = comp("blind_resume_template").layer("blind_resume_control").effect("Sport")("Menu");
    (m == 3 || m == 4) ? 100 : 0
  • Christian Simpson
    December 15, 2022 at 2:32 pm
    That worked perfectly, thank you Dan. I wish I could understand why however lol!
    What does the question mark and colon between 100 and 0 mean?
    Ternary Operator? If so, isn’t a ternary operator simply a more efficient but ultimately similar way to say the above? Shouldn’t the above still work?
    Thanks again for all the help you provide the community.
  • Dan Ebberts
    December 15, 2022 at 4:46 pm
    Yes, ternary operator. Yours should work if you balance a couple of mismatched parens I think.
