Activity Forums Apple Final Cut Pro Legacy Logging Problem with Audio
  • Logging Problem with Audio
    Posted by Joe Colombatto on December 12, 2007 at 10:05 am
    Greetings and Happy Holidays.
    For the second straight project in a row, at the very end of logging footage I encounter
    the following message: “The audio sample rate of your captured media does not match the
    sample rate on your source tape. Make sure the audio sample rate of your capture preset
    matches the rate of your tape.”
    When they talk about rate, aren’t they talking about kHz?
    I’ve got the the Log and Capture Setting at DV NTSC kHz.
    On Clip Setting I’ve got Audio checked on, but the Input Channels is “Grayed Out”.
    The Source media is 2 separate mono tracks. And yet the Sequence Setting
    for the project is set at Stereo. But this wouldn’t affect the “Rate” would it? My Sequence Setting Audio is set at 48 kHz.
    Any advice?
    Joe C.
    Kevin Hamm replied 18 years, 9 months ago 2 Members · 1 Reply
