Activity › Forums › Apple Final Cut Pro Legacy › logging on PC exporting clip list to FCP. Does this program exist?
Posted by Andreas Karoliussen on May 24, 2006 at 12:45 pmIs there a free or cheap logging program/application for PC that can export batch lists to Final Cut Pro?
IAndreas Karoliussen replied 20 years, 4 months ago 4 Members · 5 Replies -
Donato M. rondinelli
May 24, 2006 at 1:12 pmFree?
If you’ve used Excel sheets than I guess you’ve seen something similar to this: https://www.larryjordan.biz/goodies/index.html
Find someone that will give you a copy of Avid Medialog. It’s a stand-alone logger that comes with every Avid and owners are allowed to distribute it (for the purpose of logging). It includes machine control. Sebsky is a free program that will convert an Avid ale file to FCP for batching. https://www.dharmafilm.com/sebskytools/-dMR
John Fishback
May 24, 2006 at 7:50 pmhttps://www.digital-heaven.co.uk/movielogger/
John
Dual 2.5 G5 4 gigs RAM OS 10.4.3 QT7.0.3
Dual Cinema 23 Radeon 9800
FCP Studio 5 (FCP5.0.4, DVDSP4.0.2, Comp2.0.1, STP1.0.2)
Huge U-320R 1TB Raid 3 firmware ENG15.BIN
ATTO UL4D driver 3.50
AJA IO driver 2.1 firmware v23-28
SonicStudio HD DAW, Yamaha DM1000, Genelec Monitors -
Rick Dolishny
May 24, 2006 at 9:13 pmAmazingly not really.
The Executive Producer is incredibly expensive and does a lot but what you’re asking for does not exist. I would avoid the Excel route as it’s picky about colons and Drop Frame NDF issues of course.
Sadly no one has come up with a $30 quick logger ala Avid logger or the excellent Discreet Logger. Although this is the first I’ve heard of https://www.dharmafilm.com/sebskytools/ … still it’s a bit confusing in a production environment where you have mostly interns or Jr. Editors doing the digitizing (ie: import an ALE then convert then import a .txt into FCP… aargh!)
Rick Dolishny
Discrete Editors COW Leader
http://www.dolish.com – http://www.digitalimagefest.com -
John Fishback
May 25, 2006 at 12:51 pmHere’s another logging app. I’ve not used it, but it looks promising. And, it’s free! https://dvcreators.net/qt-movie-notetaker
John
Andreas Karoliussen
May 26, 2006 at 9:37 amThanx for all Your suggestions!
in my case Im logging from tape, not file, so both “Movielogger” and “QT-movie-notetaker”
Does
