Activity Forums Adobe After Effects Logging off PC after AE render is compleet
  • Logging off PC after AE render is compleet
    Posted by Brent Smith on August 5, 2008 at 8:20 pm
    Is there anyway to tell your computer (PC) to log off after your AE render is complete? The reason is that at work our computers lock themselves after 15 minutes of rest and in order to start them up again you need to log back on. But if you’re a different user than the original one who started the render and try to log on yourself (using your own logon name), you must first log off the current user which would in turn cancel/stop the render. But if there was a way to have the computer log off after the render, than you’d know it’s complete and could log on as a new user.
    Brian Lynn replied 18 years ago 2 Members · 1 Reply
  • Brian Lynn
    August 12, 2008 at 12:22 pm
    I would suggest requesting a dedicated machine, off the coporate security protocols, that you can use as a render machine…
    Another option is rendering to image sequences intead of video clips when you have a complex project. This will allow you to start and stop the render at will.
    When I stop a render of an image sequence (at least in CS3) the render cue places a new render cue in line which which automatically picks up the frames where the first render left off.
    After Effects has an option for numbering images, I leave mine set so that it numbers images based on frame number… So if something does super-crash and I can’t use the automatic restart that the cue makes, I can go to the render folder, and check the number on the last frame rendered. Then I can go back into my AE project, change the time from a clock counter to a frames counter, set my work area to start at the first frame that wasn’t rendered, and restart the render from that point without having to redo the entire thing.
    As far as I know the only “post render” action you can do is set in the Output Module tab in a drop down menu, and does not include a log-off after render… There is also Aerender which is found here:
    Windows: \Program Files\Adobe\Adobe After Effects CS3\Support Files
    Mac OS: /Applications/Adobe After Effects CS3
    It has lots of rendering options for automation, but I dont think it includes a log off method.
    Brian Lynn
