Activity Forums Avid Media Composer Logging EX files
  • Terence Curren
    March 24, 2009 at 4:53 pm
    Better yet, update to the current version (3.5) and use Avid’s AMA function. You can mount the volumes that have your EX media and immediately see the clips and even start editing with them if you choose.
    You can also use this to select the ones you want to keep, and then transcode them if you want to. But you don’t have to, you can just continue using them to edit with.
    Zero import time.
    Terence Curren
    http://www.alphadogs.tv
    http://www.digitalservicestation.com
    Burbank,Ca
