Activity › Forums › Apple Final Cut Pro Legacy › logging: can you input numbers from a paper edit
  • logging: can you input numbers from a paper edit
    Posted by Bob Cole on January 17, 2007 at 12:21 am
    Call me crazy, but I don’t see how you’re supposed to enter a “paper edit” list of timecode numbers for batch capture. Does batch capturing really require you to scrub through the tape, hit the I and O keys, etc.? Or is there a way to input a paper edit list, type it up, and let FCP do its thing?
    Sorry if this has been covered — I did a search and maybe I am just not using the correct terminology.
    — Bob C
    Shane Ross replied 19 years, 8 months ago 3 Members · 2 Replies
  • Tom Wolsky
    January 17, 2007 at 12:28 am
    If you have the paper edit done in a spread sheet with the right column format you can import it as a batch list. Otherwise you can input TC numbers into the log and capture window and save the clip as an offline logged item.
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
  • Shane Ross
    January 17, 2007 at 12:53 am
    Larry Jordan has an Excel logging sheet that I have used with success in the past:
    https://www.larryjordan.biz/goodies/index.html
    Shane
    Littlefrog Post
    http://www.lfhd.net
